Draw toposurface by Contour Lines (closed splines)
It would be better for modeling contours if you could draw it by spline, isolines that enclose a region, and elevation points simultaneously.
Point are great but there is a lot of situations were the triangles that are generated by points don't behave the way you want without adding a bunch of points more.
