Automatic Wall Section Details
I would like to request a "button" in the wall Edit Assembly dialog box that would take the plan section view of the wall and create a 2d section drawing for my wall types. I have attached the screen showing the build up of a wall. I really want to put that wall on a sheet and then notate the various layers and doing so now would require that I annotate in 2d each layer when Revit already shows me the various layers in the edit assembly box.
Comentarios
I am not sure I understand what you mean, but i think what you need to do is use legends, creating wall typeswall legend.PNG
If you find my post is interesting, I will Appreciate it if you give a Kudo.
If it solves your problem, please click Accept Solution.
