Selection dots at selecting linework overrides of cut elements in section views
On behalf of a user from Germany: Selection dots should appear at selecting linework overrides for cut elements in section views
Currently there is no selection dot at the ends of lines created by linework override on the top of cut elements in section view by design. If the elements are projected under the lineweork then there is selection dots.
0
votos
