@A_MAQ, could you please elaborate on how you would use this info? I'm trying to get a better grasp of your desired workflow. It helps make sure we have a shared understanding of the problem.
the case I faced it with my workflow is I am requested to delete every unused room separators from a file I am working with , so I need to know the associated level to be sure this room separator is for a specific room in specific level
yes as you suggest, selecting the line and need to see a parameter telling me the level
and the most important thing if it can be done is it the line is roam bounding or not
thanks
10-01-201808:11 AM
10-01-201808:11 AM
Considering the level of the room separation line affects room bounding, it seems a terrible workaround to have to move this in 3D view. These should act more like model lines and/or at least have the level and level offset shown under properties.
