Sun Path - Automatic Update when changing Orientation
At the moment, when you change the angle of True North, if the sun path is turned on, it does not update automatically. It needs to be turned off and back on again to see the change. (See Video)
It doesn't even update when you switch between views and back.
Can we please fix this so it automatically updates.
