The Publish NWC add-in needs to consider linked models when exporting!
The Publish NWC add-in does not consider linked models and does not support NWC settings from a single NWC export. This needs to change, especially since I have Bridged Revit files that I need to make an NWC. I do not want to do this one by one or have to rely on a third-party app. I want to use the Batch Publish feature.
"No suitable geometry found" when using the Publish NWC add-in for Revit
0
votos
