Put the content catalog into the Addins tab
The content catalog introduces a new ribbon tab to Revit which holds a single item. (found in Revit 2024) I am short on ribbon space because there is a limit built into Revit (20ish?). This idea is to put it where many an addin that comes with the piece is stored and that would be the Addins tab. It is where AD chose to hide the eTransmit tool and the FormIt converter.
Comentarios
@MichaelWolff ,
In Revit 2025, the Content Catalog is on the Insert tab, Load from Library panel. Does this resolve your request?
Thank you for your Idea submission!
@kimberly_fuhrman-jones No, because it still clutters all the other "supported" versions.
