Project Settings
Please add a Project Settings tab inside Revit, including Project Parameters, Shared Parameters, and Global Parameters, along with the options listed below:
Inside this tab, I would like to see:
  • Manage Links: Manage links across all view templates (note: "Due to lack of access via API").
  • Project Filters: Add filters to the entire project (note: view-specific filters will override these).
  • Delete unused Fill patterns, Line Styles, Filled Regions, Fill Patterns ect.
Comentarios
The setting of a link to be halftone or underlay all in one place could just be added to the manage links gui itself.
Getting rid of linestyles and fill patterns could just be added into the purge unused gui, but I wouldn't really want it there as it would make it too easy to remove and those types of things are not the easiest to get back.
Project filters seems to be the same thing as object styles and phase filters.
I don't really see the necessity to add a specific location to do all this in one place.
I really don't care were things are located!
Project filter are not at all the same as object styles. I need the hole filter function on project level,
Filtering on project level would be time saving so we don't need to add the same filter to all view templates in a project..
