Project Parameters Applied to Families
Please allow use to apply Project Parameters to specific families and/or type names instead of just system families (i.e. apply only to Concrete-Rectangular Beam family instead of all of Structural Framing). I think it could be made easier with a filter-type application. I think this would be hugely beneficial to scheduling. I use key schedules to deal with concrete schedules and wall schedules, along with others, but a parameter used for reinforcement in a concrete beam ends up being added to a wood beam, which isn't really helpful. Similarly, having a sheathing and nailing parameter for a concrete or CMU wall doesn't make much sense either. Please don't say use shared parameters because that defeats the entire point of using a key schedule, and then I end up with several families for the same size concrete column, which is far less efficient.
