Generic model - phasing
I sometimes use generic models (voids) to create a new void in an existing object. When I do this in a floor or wall (system families) it's presented correct with the setting of the graphic overrides set in 'Phasing'. For example: I place a generic model (void) (phase new) in an existing wall, the part of the void is presented red (to be demolished) in the wall.
When I place a generic model (void) (phase new) in a loadable family (phase existing), for example a structural framing, the part of the void is not presented red (to be demolished) in the structural framing. And the void is also visible in the phase existing, although it's a void in the phase new.
Can the behavior of generic models placed on/in loadable families be adjusted, so they have the same behavior as they do with system families?
