STOP!!! renaming elements in the Project Browser when copy-paste an element from one project file to another. It makes a mess in the project browser and leads to a lot of unnecessary work to find and replace elements in families and clean up the duplicates. Rivet's built-in instructions of using select-all-in-project and then replacing with a different element does not work. That is a separate issue that I've posted about that needs to be fixed. Furthermore, sometimes the Family Name will be renamed, but not the Family Type. So, when you go into the family, such as railing, where the element is used, you cannot tell which Family the Type is being used. SOOOOO INFURIATING!!! Instead of renaming the element, give options to use existing, use new, or rename new. This is just more archaic Revit behavior that causes much unnecessary frustration.
