Select viewport and Right click to Maximize option
Need an option when you have selected a viewport and then right click to maximize view port to include all visible building elements, annotation, reference planes....
If I  create a section it cuts off half the building and then I am required to go manually adjust viewport edges to make the other half visible.
Point to ponder: this feature should probably work too when the viewport itself is turned off (not visible)
