Allow Keynoting & Tagging of Drafting Elements
While I am not a huge fan of using detail lines, there are times in which they are needed. We need to have the ability to keynote and tag items such as :
1. Repeating details
2. Detail Lines
3. Batt Insulation
4. Certain Legend Components
5. Filled Regions
6. and whatever else I missed
Sash Kazeminejad
Comentarios
Lines can represent anything though - how do you differentiate what it represents?  You can always use a user keynote.
We've made a line based detail component with a single line that we use instead of detail lines for representing flashing, etc. and a more complex one that looks the same as insulation and use that instead so we can keynote and tag.  The lack of tagging options for legend components is a longstanding issue and is one of the reason firms will use documentation phases and similar methods.
@jkidder I have done the same thing as you when it comes to dealing with items that are simply lines. I have created line-based detail components for flashing, air and vapor barriers, etc, but I think the issues with insulation and other built-in features needs to be dealt with. There are too many small gaps that need to be filled.
Using Phases for legend components is one that I have tried in the past and don't like. I use Phasing for Phasing and not for workarounds.
Sash
El estado se ha cambiado a: Archived
Thanks for taking the time to submit your idea. Unfortunately, this idea did not get the support of the community over the last 6 months and as such we will not be pursuing it at this time. Please feel free to rework (titles and clear descriptions are really important) and resubmit this one down the road.
Yes!
tagging batt insulation and repeating details is a must have.  please make this happen.
Pretty please make this an option!
Please take this out of the archive. This is still needed.
