Measuring dimensions at any angle or direction
The current workaround for measuring dimensions aligned at any angle is to press Tab button 8 to 16 times. Having to press the Tab button over 10 times just to find the appropriate snap dot only works well on walls with one or two segments at most but fails and doesn't work as intended and gets complicated on walls with more segments or at different angles. This approach drastically slows down anyone's productivity and is time-consuming and tedious. Hence, I have suggested feedback requesting a 'snap to vertex' option in the Dimension Prefer menu to circumvent this issue.
Please refer to the attached image where the dimensions on both sides of two angled walls need to be shown where we need to press Tab 10 or 16 times for one corner snap dot for the total four corner snap dot, pressing Tab (10 x 4 = 40 or 16x4 = 64) times, for two segments of wall Pressing tab would become 80 or 128 times respectively.
I am posting this Idea as a request to gather lot of support from Revit users so we can get this asap. Kindly provide your support for this idea. Thankyou
Appreciate if this issue is solved. Thankyou
