Customize Column in the Autodesk Docs section of the home tab
We would like to be able to customize the columns apprearing in the Autodesk Docs section of the home when he is selecting the Revit cloud model he would like to open. So instead of only having the following ones:
Name, Model Type, Modified Date, Modified By, Publish Status, Publish Data, Published By
we would like to at least be able to have the "Desciption" column giving the description of the files defined in BIM360/ACC But allowing to select the column (including custom attributes) we would like to display in addition of those already there will be a must. This will help users to select the right Revit file to open, publish when they are working on large project with many files and folders.
Regards.
