The length of Section Line in Dependable Views
When the length of a Section Line is manually adjusted, the change is unfortunately not reflected in Dependable Views, where the original length remains displayed. Additionally, once modified, there is no option to revert to the previous state.
It would be beneficial if manual changes were consistently visible across all views.
It is already here on Forum described: https://forums.autodesk.com/t5/revit-architecture-forum/section-marks-showed-on-different-lenths-on-...
