View Dependent Selection Options
We should have greater choice of selection restrictions based on view type.
For example, in an area plan, I should be able to restrict selections to area boundaries, area elements and area tags. I shouldn't have to tab through 10 things to select the elements that are the main point of the view.
In detail views, I should be able to choose to only select detail items and not the model.
In any given view I should be able to restrict selections to annotations and dimensions rather than again having to select loads to filter out all the walls and floors and everything else.
These options could sit in the bottom right hand selection options toolbar.
0
votos
