Double patterns
A color as Solid Fill  and 2nd a pattern.
Concrete: Grey and the concrete pattern,
Comentarios
Yes I have spent too much time on this issue. It would seem thatbthete would be a simple fix
Even better would be it Revit would allow to use any pattern as an "underlay" (and not just solids). For example: when we use concrete tiles we want to see the concrete hatch (drafting pattern) but also the tile grid (model pattern). Other examples are raised floors, gypsum ceiling tiles, ...
Perhaps every pattern could have Top part and an Underlay part. The top could be either drafting or model pattern. The underlay could always behave as a drafting pattern (Can't really think of a scenario where you want to combine to model patterns).
Hope this makes sense.
El estado se ha cambiado a: Under Review
Thanks for your submission and votes on this idea!  We are evaluating where this request falls into our roadmap and will provide an update when we have made a decision.
The Factory
Recenttly, I've faced this problem. See my trhead:
Combine Filled & Diagonal Pattern
I'll really appreciate if Autodesk solve this boring problem on next realese.
Ari Monteiro
Dharma Sistemas
It is handy but i do not understand why this is top voted.
The user interface qua parameters in revit is much more important because hatch is 2d and less relevant in the future.
Parameters in color so that can be seen is much more important in my point of view.
Hi ramon697348385,
I totally agree. By the way, I think that Revit should have a type parameter to control the color of 2D objects, such as there is for 3D objects (eg Finishing Material).
The lack of this type parameter forced me to use a workaround that involving 2D objects such as hatches.
A ideal world would be not use 2D in BIM technology, but to eliminate this use I think that several process shall be changed.
El estado se ha cambiado a: Accepted
Congrats! We think this is a great idea, so we've decided to add it to our roadmap. Thanks for the suggestion!
The Factory
Great, looking forward to this one!
Really hope the factory will implement this in such a way that you can assign any drafting pattern (not just a solid fill) as an underlay to both drafting and model patterns.
Examples that come to mind: concrete tiles, gypsum ceiling tiles, glass lines + dot patttern, ...
Good. this is long overdue. All it requires is a pattern color, and ability to select a background color. Should apply to Text and other kinds of fill as well.
Just to tack on to the end of this; one other minor improvement I'd like to see is to move the SOLID pattern to to top of the list. SOLID is probably used for well over half of all Patterns and it's annoying to scroll down to it every time. Perhaps rename or add another name just like the Line Styles use:
This can be facilitated/integrated with a color swatch library. See this post: https://forums.autodesk.com/t5/revit-ideas/project-color-swatch-library/idi-p/6670753
I am hoping this double pattern feature will allow us to choose Model and/or Drafting patterns for each selection. For example, in a wall section it would be nice to have the (now) normal CMU drafting pattern and then overlay a Model pattern to impose coursing on the wall (and as a model pattern it could be repositioned if needed).
The draw back is this might not match the position of the model pattern used on the surface/projection. Maybe there could be a "match" check box (somewhat like the match shade color with render appearance in the materials dialog)?
In Europe we often need to create drawings where elements like walls don't only have a hatch, but also a solid color (e.g. meaning the wall is display grey solid + a transparent hatch when cut):
(This is a customer wish logged by an Autodesk Employee)
Also gradient patterns would be great for presentations and landscaping.
Is there not a way to create your own patterns, you could also put both hatches on top of each other and make transparent.
Would support for SVG fill pattern filetype work for this?
It would be verry nice if you could add a background colour to a hatch or combine 2 types of hatchpaterns.
For example: I prefer to hatch concrete with the current concrete hatchpatern and it should also be grey.
This idea exists already https://forums.autodesk.com/t5/revit-ideas/double-patterns/idi-p/6323446, and has been accepted.
Please search the forums for existing ideas before posting your own.
It's also been flagged as "Accepted" in the Revit Roadmap
http://blogs.autodesk.com/revit/2017/08/31/revit-roadmap-update-august-2017/
(double patterns)
It's quite common that we need to color materials AND have hatch patterns at the same time in shaded views.
As an example to show tiles that are different for visually impaired people.
Would be neat if you added this option to materials.
Closest you can get right now is grey lines which isn't good enough.
Duplicated Idea, see here:
The Idea is currently Accepted, and the Factory (Developer Team) are working on it; see here:
You should search for similar ideas before post new one, and look at the top voted ideas.
Awesome!
El estado se ha cambiado a: Implemented
Hi Everyone,
I am happy to say that we believe we have implemented this idea with the Revit 2019 release!  You now will have the ability to apply a background or foreground pattern to materials, elements, and overrides.  Check out the feature and let us know what you think.
The Factory
So, this implementation is great, but it's flawed. You can ONLY apply a Drafting pattern for the Background.
Because we are limited by the .pat filetype, we can't create nice looking patterns that show different lineweights, colors, etc. based on the lines within the patterns. I thought this dual hatch pattern option would help with that, but it doesn't in this instance.
I want to create a 2x4 ceiling pattern, then have lighter lines at 6" intervals along the 2' span. This can't happen. I can easily create a basic hatch pattern in Revit for the 2'x4', and I could easily create a basic pattern for the 6"x4', but I CANNOT put both of them on the same material?!?! WHY?
What is the reason behind implementing something half way or partially? Or maybe I'm just crazy and something is wrong. Is anyone else seeing this limitation? Obviously this in Revit 2019, with the hotfix 1 installed (2019.0.1).
Implementing SVG would have helped with this. So would having 2 .PAT with control over lineweights and colors do the trick?
Having 2 patterns with full control over each would be best. And that means allowing us to use both model OR drafting for either the foreground or background patterns.
But yes, hopefully there is still some work being done on the patterns in general, as the .pat file is getting old...
Unfortunate as if often the case, new features just become a Check Off to
development. Further enhancements making the feature more usable seem to
get pushed way to the back of the line.
Agreed. Many of the "new" features are implemented exactly as a user has described without any extra thought put into how they will be used in the actual software. We look to the developers to actually think about user experience and implementing things that work all around, not just partially.
Do we have to create another Idea and get 500+ votes to make a previous Idea implemented fully?
I've seen it many times over the years - features are implemented from Wish
Lists, but how they the features are to be implemented don't seem to get
the same treatment. Once a feature is put on the Development List, surveys
should be sent out requesting the Key Features of implementation.
Priorities should then be set to those features - because they won't be
able to get to all of them. Besides Focus Groups, Comment Engineering (ala
Reddit) would also help.
Hi all,
Thanks for the feedback about model patterns being used for both foreground and background.  We appreciate your thoughts and time/effort to provide your feedback.  We would encourage you to create idea for additional functionality in this area.
As a workaround to this issue with model and drafting patterns, it is possible to combine patterns in the text PAT file or to switch (or create a copy) a pattern from a model pattern to a drafting pattern by editing the PAT text file directly.  There is a thread on AUGI related to this that might be helpful: http://forums.augi.com/showthread.php?71026-Editing-the-Revit-Hatch-PAT-File
As to the comments about our process for addressing wish list items, I'll try to answer without being defensive (though sorry if it comes off that way).  We try to gather as much feedback as we can while researching ideas and during the development process.  In this case, we connected with people on this idea thread as well as the original poster directly to get their thoughts and understand their requirements, we posted a survey on our preview release site with our beta testers, and included customers directly with our teams as they developed the functionality (called sprint demos).  Through out the process, we made adjustments based on their feedback to try and best meet the needs of everyone.  Our goal is to listen as much as possible and provide an experience that meets the needs of most of the customers we talked with - though, we know that we aren't able to fulfill all requirements from everyone and we are not able ensure that we have collected every possible piece of feedback before we release a feature. Your feedback after the release is very helpful and will help us to decide what more functionality we should prioritize.  Please keep the comments coming.
@harlan_brumm, thank you for the information and I do apologize for my tone :cara_guiñando_un_ojo: but it can be frustrating seeing how much we all pay for this and it just seems we are continually helping to test the software and help improve it without getting a ton in return. Obviously we see the improvements in the software eventually, so that is a plus!
In regards to changing a model pattern to a drafting pattern, I'm not sure that would actually solve the issue. Since drafting patterns scale and behave differently in general, I'm assuming we'd see the same behavior when it's applied as a double pattern and things wouldn't look the way we would like. I have yet to test this, so maybe someone else on this thread has and can shed some light. If not, I'll try as soon as I can and report back.
I can back up @Anonymous 's comment about getting users involved. I was involved in that project, as an end user, and we (multiple users) meet every two weeks. I posted about that here: https://bimchapters.blogspot.com/2017/12/revit-product-development.html
I will admit I personally overlooked the drafting vs. model patter thing... once I realized it I emailed the team working on this, but at that point I think Revit 2019 was out. Ugh, missed opportunity - sorry. Personally, I would have liked to represent basic masonry coursing in sections; brick section pattern (drafting) with horizontal coursing lines (model).
I think @casquatch is correct in that the suggested workaround will not work - as you would not be able to control the color of the 6" lines separately if all in a single pattern definition. On a related note, just sharing, here are a few posts I wrote on the subject:
Revit Fill Patterns
Revit Fill Patterns - Part 2
Revit Materials: Model Pattern Position
I was also part of that test group together with Dan but I didn't want to break the NDA. As Harlan has replied, I figure it's fine to share some thoughts now.
I must say that the team working on this took every effort to gather as much feedback as they could (including calling the people who had added comments in this thread). They make mock-ups of all dialogs and workflows and then gathered feedback again. It was the exact opposite of "let's just smack a new feature in there and call it a day".
For double patterns they had to make adjustments to import and export of dwg's, change the V/G dialogs, change the patterns dialog (they didn't have to do that but they did to improve workflow), change filled regions, change phasing overrides, change element overrides, etc etc
However, in the end every new feature brings up other questions: why not have a pattern generator, why not have rotating drafting patterns, why not have aligning of patterns on curved surfaces, etc etc. In the end a judgement call has to be made when to stop, or this team will be working on patterns for 5 years straight (and not tackling of the other +6000 revit ideas).
As for not having full lineweight control over patterns: it's an issue that has discussed a lot and it seemed really hard to find a consensus in the user community on HOW that should be handled. There's a ton of different ways to do it: control per pattern, per material, per object styles, V/G, phasing, element overrides, ... You could just say "do it all" but that's both going to take development time away from other much needed features and make Revit an even more complex beast to learn and manage.
As for why not model+model pattern: as I understood it, this would open up another can of worms (can you align/rotate both model patterns separately etc?). I felt that this type of usage would be better fixed with a pattern generator (which is one of the top 5 Revit ideas, so it's bound to happen someday). Remember, time the team didn't have to spend on making model+model pattern happen can be reinvested somewhere else on the top+20 idea list. If you want a fix in the meantime I highly recommend the free PyRevit plugin which has a great pattern creator.
Lastly, I would recommend everyone to join the beta program. You'll get a better appreciation of how much effort the developers put into new features and you'll get a chance to provide feedback before features make it into the product.
Thanks for all the responses. I'm just wondering (out loud) the process of
"enhancing an enhancement" and if these types of suggestions carry as much
weight as "new features". There are many enhancements which have been
requested, but workarounds have been "canon" and seem to never make it into
the application (e.g. splitting schedules over multiple sheets, making
curve edges invisible, maintaining SKP smoothing groups,et al).
Instead of a separate Pattern Generator, why not support SVG as a pattern
format? You'd get everything - bitmaps, vectors, line weight, etc. No need
for a separate app and users could create them using applications they're
already comfortable with.
BTW - What's the process for apply for the betas?
The easiest way to be added to our preview release (beta) program is to reach out via email to revit.preview.access@autodesk.com.  We will then get you setup.
@davidwilliamedwards
You can reach out to revit.preview.access@autodesk.com to join Revit Preview (=the beta program).
As for your question about the "enhancements": when you look at the detailed change logs you'll notice that continuous small enhancements are being made all the time. I wouldn't be surprised that more coding time is spend on fixing existing bugs and small enhancements than creating new features. However, these small changes are often not promoted like the big new features are so they often slip under the radar.
As for the examples you mention (splitting schedules, smoothing groups in sketchup, ...), these are all on Revit Ideas, just like +6000 other suggestions. I'm sure splitting schedules is going to be tackled someday (as it's a very popular Idea in the top +50), but there are +1000 ideas with more votes than Sketchup smoothing groups so I don't expect that to be tackled any time soon.
What information do you need besides basic contact information? Years of
working with Revit - other work done for Autodesk, etc.? TIA!
What version of Revit does this begin in?
It's implemented in Revit 2019.
El estado se ha cambiado a: Gathering Support
