Disable selection of model and detail categories beyond the cropped region
I typically make drafting edits within sheet viewports. Sometimes when I try to double click outside of the viewport a model or detail category (i.e. wall, floor, region, detail group, etc.) gets selected even though the view is cropped and I cannot see what I am clicking on. It does not matter how far away you click, if you happen to click exactly where something exists in the model when you are trying to exit the viewport that item will be selected. It is quite an annoyance and can be fixed if somehow everything outside the cropped region cannot be selected when "Crop View" is enabled. Refer to video below/ attached.
