Make it easier to re-run a macro (like it was in Revit 2024)
In Revit 2025, pushing the Macro - Run button closes the Macro dialog. Then when you reopen the Macro dialog the module tree is collapsed. So you need to re-expand the desired module and re-select the previously selected macro. Would be great if the dialog were modeless or if it remembered the expand/collapse state of the modules and which macro is selected.
