Reconsidering the old version and Request for Share View New Update
Hey Autodesk Team,
I wanted to share some feedback about the recent update to the "Share View" feature in Autodesk Construction Cloud. The new version seems to have removed a lot of the interactivity that we heavily relied on.
Previously, when we generated a "Share View" from a Revit file, we could send the link to external design or execution agencies. They could open it in Autodesk Viewer and interact with the model—section it, select elements, check properties, isolate components, etc. This was super useful for us because it meant that even if these external partners didn’t use parametric software, they could still fully engage with the model and provide detailed feedback.
However, in the latest beta version, "Share View" only allows for a basic 3D view where you can rotate the model but not interact with it in detail. This change is a big step back for those of us who need to share detailed model data with others who are not using Autodesk products daily.
This is particularly challenging in markets like ours in India, where many design consultants don’t work with parametric software. We rely on tools like "Share View" to help bridge the gap, communicate our work, and drive better collaboration. The removal of this functionality means losing a critical piece of our workflow and will impact our ability to implement a parametric working environment effectively.
We really need the full, interactive "Share View" back! This feature helps so much with design communication and collaboration, and without it, we’re losing a lot of value.
Can you please consider bringing back the full functionality of the "Share View"? It would make a massive difference to many of us.
Thanks!
