Using "Split with Gap" tool on multiple elements at once.
When using the "Split with Gap" tool, is it possible to split multiple objects at once? It would be nice if I could hold the clicker to essentially draw a line that could split many objects at once. I use this tool often to create gaps in conduit to insert offsets. I often have conduit runs of 15-30 conduits that all need to be split. Splitting each one-by-one and trying to have the gaps line-up can take a long time. If I could split them all at once it would be very helpful. Thank you.
