My Team faced with problem of overlapping ordinate dimensions in Revit. When the size measures every gap, then with any modifications: reversing the text, changing the scale, removing the opacity behind and so on, we cannot avoid this issue.
There are no plugins that can help us avoid this problem. Also our plugin developers do not have possibility to write the code, Revit does not allow this to be modified. We are working with Modplus that can do jog of regular (continues) dimensions but not work with ordinate type of dimensions.
I would appreciate any help. Our team is looking for an automated solution for big package of drawings. This is really important type of dimension for construction.
Thank you,
