Room Parameter Data available in Material or another Tag
It would be great if I could access the Room (built-in) parameters in annotation Tags so I can use already established data for populating enlarged finish plans.  I'm using room tags for this now, but you can't multi-leader those tags so we having extra lines drawn in to establish start and finish points for accent walls.
