Remember "Specify ..." selection for cloud models across Revit sessions
When opening models from ACC/BIM360, we can use the Specify... menu option to select which worksets to open when loading a model.
Current behavior:
  1. Use Specify... to open a model.
  2. Do work, close model.
  3. Click on model name to launch model and Revit remembers that Specify... was use previously without having to select the menu option again.
  4. Do work, close model, and this time also close Revit.
  5. Start Revit, click model name to open. Revit has forgotten that Specify... was used previously and reverts to default Open behavior with all default worksets open.
Desired behavior:
  1. 1-3 above to remain.
  2. Revit should remember last user action (Open or Specify...) after the program closes.
  3. Optionally, Revit should remember the last load state worksets were in if Specify... was used.
  4. Users save valuable time instead of re-selecting worksets again each time Revit restarts.
