Whenever we create a section, Revit typically creates a new section, along with new view that contains everything you don't want to see. If we can have a personal section view assigned to only our use, so that unless we check the box to say "Community", it will only use that view (SECTION VIEW.USERNAME) whenever we create a new section. In addition, because it's a personal section view, it will have the view settings to show exactly what we want to see in a section and not have to liter the enter model with new section symbols, or have orphaned section views in the model for others to clean up after.
