It is recommended that the number of imported points for creating a solid terrain model in Revit should be able to exceed 10,000 objects. When dealing with larger terrains, survey data often exceeds 10,000 points to ensure the accuracy of the terrain. Additionally, there are often characteristic lines during terrain surveying, which need to be drawn to ensure the consistency of the terrain model with the actual terrain.
建议revit导入点创建实体地形模型时导入点的数量能突破10000个对象。地形较大时,测量数据往往超过10000才能保证地形的准确性。而且地形测量时还会有特性线。需要通过绘制特征线来保证地形与实际的一致。
