Apply View Template directly from Properties Pallette
We should apply any existing View Template to any active view directly from a drop-down list in the Properties Palette. Drop-down lists should by widely available in the Properties Palette for any possible item or parameter.
Comentarios
I could see this as a dropdown with <none> at the top and only listing the templates that can be applied and then at the very bottom having <customize> so you can still access the dialogue.
Also one minor thing I find very annoying is when you create a a view template from view it does not auto apply the template to the view you used to make it.
