Dimension Styles Linetype Type Properties
I would like to have a parameter for the dimension linetype and dimension extension linetype to be available within the Type Properties window.  For example, create a dimension that has the dimension lines to show as dashed, hidden, or any other linetype....same with extension lines.  Only way to create this now is to select each dimension created and override by element....
Comentarios
Thanks for taking the time to submit your idea. Unfortunately, this idea did not get the support of the community over the last 6 months and as such we will not be pursuing it at this time. Please feel free to rework (titles and clear descriptions are really important) and resubmit this one down the road.
El estado se ha cambiado a: Archived
