Make Balusters Have a Profile Based Option
To help make railings more user friendly it would be a good idea to have the option to make balusters profile based. More often than not I find myself either using the round or square baluster profiles and if I ever need to change the thickness of the baluster I need to edit the family and add the thickness I need. There should be a way to integrate straight baluster profiles with an optional thickness instead of needing to edit the family. Sometimes special balusters are required that do not have a linear profile (i.e. the baluster has a 'wave' to it instead of being straight), this particular case should either be a sub family or a sub group within the railing type properties (i.e. have a Linear Railing vs Specialty Railing similar to Walls and Stacked Walls OR within the type properties of the railing have a toggle or option of a linear (profile based) baluster vs a specialty (family based) baluster.
