Default setting for CAD link "Location Position Changed"
Every time I click save, Revit keep on asking Save or Do not Save Dialogue box. It is affecting our workflow as it need action from us every time if we save the file. Please add "Do not ask again" option or "Make this Default" to save our valuable time. If we click unknowingly Save it will overwrite original CAD file, which is irreversible process. Please kindly fix this issue.
Comentarios
I think this is a bug that happends to my since Revit 2017. I save back the revit orientation to the CAD, modifiying the CAD (distorting is coordinates), and then conitues to rotating revit true North again (because the CAD has updated).
To solve this I dissallow Shared Position on the CAD properties as soon as I adquire it. But it shouldn't be te solution.
@samuelsanf Yes, I agree. "Disable Shared Position" shouldn't be the solution. Better to set "Do not Save" as Default. If I link 4 or 5 CAD files, I have to click "Do not save" 12 or 15 times (It will ask 3 times for same CAD file) every time I sync the file with central model. It is better to give "Do not ask again" with tick mark option for that to make it default setting.
Hi @kimberly_fuhrman-jones , I report this issue on the Beta portal and got response from Mihaela Stan.
I don't know if should be marked as Accepted or something.
Thank you, @samuelsanf , since this seems to be a "bug", is it ok to move this thread to the Revit Architecture forum?
