NC signature settings separately for plates and beams
Hello Autodesk,
For the future integration of NC functionalities for steel construction, it would be important that the signature settings of the parts for plates and beams are possible independently of each other. The machines for plate processing and beam processing often have different options and requirements. The NC data would then be better adapted to the respective machine.
In Advance Steel, the signature settings, especially the arrangement of the signature on the plate/beam, were previously regulated with common settings. If there was an option for structural steel in the future functionalities, that would be very helpful.
Regards
Elias
Comentarios
Thanks for bringing this up Elias.
