Visible warning in panel schedule for over loaded circuits
Currently - if a branch circuit breaker size is adjusted and the associated load is exceeding 80% of the circuit breaker rating, REVIT will pop up with a warning at the bottom right of the screen. This only occurs if you actually adjust the branch circuit rating (IE if the circuit is overloaded on creation, the warning will not pop up).
In the panel schedules "Set Template Options" -> "Circuit Table", there is a box for "Auto-shading for displaying load" to automatically shade cells depending if any load is on that phase/circuit. My initial thought is to see if we can please get a similar check box allowing an auto-shading if the circuit load exceeds 80% of the circuit breaker rating? The check box could auto-shade the load, circuit breaker rating, entire row, or however.
Sometimes I create new circuits, they come in at the default circuit rating (20A in my case), and I forget to go back and adjust them. Even if it wasn't implemented via shading and was done in some other manner (maybe conditional formatting), it would be very appreciated to have some kind of easily visible warning/reminder in my panel schedules that highlights the fact the circuit is over loaded.
