Underlay - control VG by View/View Template, not Additional Settings
The VG for Underlay should be controlled in the View or View Template, not in Additional Settings. Underlay VG should be customizable for different views, not controlled globally under Additional Settings. While you're at it, also add the ability to control VG or turn off Surface Patterns.
