Show earth hatch in plan when cutting through topography
Right now, when you cut through topography in Revit, it just hides the topo. When you cut it in section, you get the nice earth hatch. It would be nice if the topo object showed an earth hatch pattern when cut in plan outside the building pad and foundation walls. It would look more legible and be easier to read that the Level is subterranean. Of course this would be a View Graphics Override toggle under Model -> Topography
