Toposolid workflow and tools #2 - Modify Sub Elements edit mode
Create an Edit mode for Modify Sub Elements. We've become accustomed to having to double-tap esc in Revit to end a command (which in itself is stupid. If I want to end a command, I want to tap esc once. I don't want to tap esc and then have to tap a second time to confirm what I just wanted to end). However, in Modify Sub Element mode, you only tap esc once to end a command while in Modify mode. If you double-tap esc, Modify mode is exited. It's so annoying and counter-productive to habitually double-tap esc thinking to end a command but stay in Modify mode, only to exit Modify mode and then have to select the Toposolid and re-enter Modify mode. This has been brought up by others users in another suggestion thread.
0
votos
