Save created Filters in a simple txt file
We created a template file with over 200 V/G Filters for Architecture, Structure, MEP, Landscape, etc for any possible situation. This way we can maintain a single template revit file for any project for the entire company. Yet , we don't want to load all the filters in any new project, we want to load only the relevant filters for each project.
It would be great if we could save ALL the Filters in a simple txt or xml file, something like a family catalog file, then load only the relevant filters in new projects.
Certainly we can save a revit template file with all the Filters. The problem is when we delete a filter by mistake, or when we need to load additional Filters later in the project. We could also provide this Filters "library" to all our subcontractors, so we could work under the same graphic rules.
Ideally , Autodesk should provide a Standard Filters Library in the default Revit installation, similar to the Materials Library.
