Show Room Footprint Correctly when using Color Schemes
Currently Revit "paints" the color of a room to the centerline of walls when using a Color Scheme in a plan view, despite having area calculations set to face of wall. I was hoping that the perimeter calculation updates talked about in Revit 2025 would correct this, but it seems like it has not. I know the area calculations are correct by cross referencing with a filled region, but color showing up in doors, windows, openings, etc at the wall centerline leads non-revit user team members to suspect that the area calculation is not accurate. It would be great if this was corrected.  Thanks!
