Linework Tool
I'm wondering why linewoork tool blue controls display at each end of the edge. You can drag these controls so that the new style is applied only to a segment of the edge is applied only to projection edges.
Would be nice to have that option at all times.
Also keep the blue dots visible so it can be moved at any times, not just when is created
Comentarios
I wouldn't say at ALL times, as that could be a lot of little blue dots floating around. But it would be nice to have an option to reveal modified linework.
If you click a line using the linework tool that already has linework applied to it, the grips will reappear at the locations they were previously adjusted to.
It would be nice to add a little checkbox though in the tool to reveal modified lines.
You had me going for a second there @Mike.FORM :cara_sonriente_con_la_boca_abierta_y_sudor_frío: I thought I was missing it all along.
