Rotate Host Plane in Family Editor
Found this in the archive as posted by someone else, but reposting because I just came across it and I'm having the same frustrations.
If you are creating any kind of Hosted Family, the work plane is always horizontal. A "floor", if you will.
Anytime you create Wall Hosted or Ceiling Hosted families, you need to twist your brain around to figure out which direction is which.
For example, a Wall Hosted family must be created lying on it's back, since the host (Wall) is horizontal.
Allow us to select an orientation for hosted families so we can specify where the host is.
At a minimum, allows us to select Floor, Wall, or Ceiling orientation.
0
votos
