Manage Defined Site per View
I have a Master site Revit file.  Multiple building revit models are referenced in.  Some models are identical and are placed multiple times at different locations.  When in a building file, there are multiple plans to show the different site contexts for each Defined Site Location.  It would be nice to be able to control the defined location PER VIEW instead of only globally.  That way the user would not have to switch locations when printing different sheets.
Comentarios
You also could use the Master File for each sheet. Set the link defined "by linked view" plans of a kind, create view tempaltes as you need, then create Scope Boxes on every location of the link to use as Crop Region.
Duplicate the view for every linked model and change the scope box.
Thanks for taking the time to submit your idea. Unfortunately, this idea did not get the support of the community over the last 6 months and as such we will not be pursuing it at this time. Please feel free to rework (titles and clear descriptions are really important) and resubmit this one down the road.
El estado se ha cambiado a: Archived
This would be a great option in the view templates so all your views could be ready to export without changing this setting each time.
