Sticky parameters when editing schedules
Schedules are adjusted using their special type properties dialogue window. If you have a large schedule, doors for example, they may show more parameters than fit that window. So once you have pushed that parameter to its correct location in the first tab and now want to adjust its justification in the fourth tab, you need to find you parameter all over again. I would propose to have Revit stick to the parameter that was last selected in one of the tabs. I admit this makes most sense with tabs 1 and 4. The parameter you were last editing inside the actual schedule might even be pre-selected when entering the props menu.
