Show which columns have filters
Schedules may have filters applied. You need to go to the filters tab in schedule's type property window. The idea would be to show columns that have a filter applied by adding a little symbol (a funnel springs to mind) next to its header. Or print the column in bold or italics. Or make it inverse
Comentarios
To stay within Revit look-and-feel, making the filtered column show blue but print black, just like the active section end, would be nice.
how can I filter by column name in ascending and descending order?
@autodesk
