Options improvement - Fit to View on view change
This feature does not work as it should.
When the view rotates and zooms it has two flaws:
Firstly it almost always chooses to look at an object from behind.
All electrical fixture on walls always seem to end up being viewed from the wrong side of the wall which puts the wall in the way - the element can't be seen unless the view is manually rotated. This behavior is very consistent.
Secondly, it accounts for elements that are not visible when picking the zoom distance.
If there is a hidden piece of geometry the view will zoom in only as far as the extents of the geometry that is invisible but not cut by the selection box boundary.
This means that the view is zoomed out much too far, the elements you want it to zoom in on are frequently so small that they can't be seen and you have to manually zoom in each time the command is used. This behavior is also very consistent.
If these two things could be improved I would appreciate it.
