PDF EXPORT BUTTON, REVIT DOES NOT SEE OUR BUILD DOCUMENTS IN AUTODESK BUILD
EXPORT TO PDF, IS NOT LINKING WITH AUTO DESK BUILD FILES! This makes the PDF EXPORT button useless if we can't see our files in the build folders! Is there a setting im not turning on to see our own files from Revit? Were currently uploading from Bluebeam pdf to the Autodesk docs file using desktop connector. Integrate desktop connector with revit..? Is there a setting in Revit to enable seeing our own build docs in Revit? It seems Revit should just incorporate how desktop connector works.
0
votos
