Edit Lighting Calculation Luminaire Plane
We should be able to manually edit the Lighting Calculation Luminaire Plane. Revit calculates this based on the lowest placed luminaire. Where I mostly run into this is when I'm using emergency lighting units. The ELUs may be placed a 7' but all the main lights are at 10'. Revit will calc assuming all the lights are at 7' which is very incorrect.
See discussions at the links below.
https://forums.autodesk.com/t5/revit-mep-forum/lighting-calculation-luminaire-plane/m-p/5499066#M264...
https://forums.augi.com/showthread.php?150392-Lighting-Calculation-Luminaire-Plane-(LCLP)-Issue
