Allow or forbid connections according to material
It would help me in modelling existing conditions if walls connected to one another when they are of the same material. Right now I need to model brick walls somewhat short of a concrete one crossing its path, dis-allow the connection then extend it to meet the concrete wall.
Comentarios
@MichaelWolff : see these ideas
(1) Material priority’s to setup how materials/components (wall, floor, roofs, …) join - Autodesk Commun...
(2) Drag and drop Wall Layers in Wall Joins - Autodesk Community
they are cross referenced with each other in the comments
I would consider a combine with the first. Please ask @kimberly_fuhrman-jones to combine with the one you feel is most relevant.
@wr.marshall @kimberly_fuhrman-jones I have seen these ideas and think them too complicated to be implemented in the near future - if at all. My proposal would be to have the allow/disallow join button to be material sensitive.
