Fix transparency print problem
It is bad enough that you need to use the rasterized mode when printing transparencies generated by filters or general overrides.
I just realized that this approach does not work at all if the printed view is in wireframe mode. Surely this is not intentional, especially since the transparent element appear correctly on screen.
Comentarios
