Creating single pdf packet with multiple sheets (does not remember the order in which the sheets were first selected)
Revit creating a single pdf document with manually selected sheets, its does not remember the order in which the sheets were selected. Every time, forced to reorganize the sheets in which you selected them in the first place! This is common sense. As soon i select hide un-checked views/sheets it does not keep it in order of first selected. If this is missing feature, then it should be added.
Please fix!
