I lose count of the amount of times that I do this but why can't Revit have the option to right click the mouse to copy, cut, paste to/from the clipboard?
Maybe because ideally speaking one is not supposed to rely on the Copy/Cut/Paste from clipboard function except in very particular cases and most probably because using ctrl+C or ctrl+X and ctrl+P do the job and serves the purpose more consistantly and is more reliable than mouse clicks in popup menus...and it is still there on the ribbon...in other words no added value
It would simply be a redundant feature the option for paste "Aligned to..." is available both in the Ribbon and again and as hotkey short cute
ie: how can a right click to pop menu then scroll and left click to get to submenu and again left click be any easier than 2 clicks on the ribbon or setting 1 keystroke to get to any of the options made available in the Paste drop down menu!!
Do I ever use paste aligned? to a certain extent yes; read again "in very particular cases" ... if you want be to be more precise, maybe 4-5 times generally through out the very early stages of a project... probably the technical draftsman uses it more . Still in my opinion that doesn't justify the brilliant idea
